Enter to Win: Incredibase575 Single-Cabinet Home Theater System from ZVOX!
Status
Not open for further replies.
Q
q2bon2b
1. How many TVs do you have in your home?
Four
2. How many of them have crappy sound systems built-in?
Four
3. How many of them are connected to an external audio system?
Two
4. Do you own, or intend to buy, a stand-alone iPod speaker system?
Own one.
O
owasse
1. How many TVs do you have in your home? - 5
2. How many of them have crappy sound systems built-in? - 5
3. How many of them are connected to an external audio system? - 2
No
W
wesley63
4
4
3
Bought a Cambridge Soundworks i765 for my wife's office. Not bad.
AzN_plyR
5
4
3
No
STRONGBADF1
STRONGBADF1
Contest Questions:
1. How many TVs do you have in your home? 3
2. How many of them have crappy sound systems built-in? 3
3. How many of them are connected to an external audio system? 1
4. Do you own, or intend to buy, a stand-alone iPod speaker system? I intend on buying one...so my wife will stop talking about it.:)
Midwesthonky
Two
Typical built in left-right speakers.
One
Do not own, do not intend to buy. Use an audio adapter to tie into primary audio system when so desired else stick to CD's
Anagoge
Anagoge
1
1
1
I own a desktop HD radio with an iPod dock, but I use it mainly for radio, not for iPod music.
JerryLove
JerryLove
1. There is one television and one projector in my home.
2. I believe both have built in sound.
3. Both are attached to external stereos.
4. I don't buy much for the iPod as I own a Zune.
XEagleDriver
XEagleDriver
1. How many TVs do you have in your home? - 4
2. How many of them have crappy sound systems built-in? - 4
3. How many of them are connected to an external audio system? - 2.5 (one system has active speakers for DVD but, due to the TV's age, not the cable signal)
4. Do you own, or intend to buy, a stand-alone iPod speaker system? - No, but I own a Sansa Fuze for use with two active-speaker pairs, and two vehicles with built-in AUX inputs.
XEagleDriver
JonnyOzero3
1. How many TVs do you have in your home? - 3 (one is a projector)
2. How many of them have crappy sound systems built-in? - 2 (Older Sony CRT's w/ TV sound)
3. How many of them are connected to an external audio system? - 3
4. Do you own, or intend to buy, a stand-alone iPod speaker system? - Nope, I'm not an iPod user but I have a Sansa MP3 player. That said, if I was going to integrate my MP3 library to my system, I'd probably go with some sort of music server option. As it stands, I just hook up my Sansa, or a friend's iPod direct into one of the AVRs in my house (Via either the iPod USB connection, or just analog audio L/R) and use my existing sound systems to play music, if the need arises. I also have a set of small active speakers to use away from my main setups.
N
Nugu
2
I wouldn't consider them complete crap but they both suck at any frequency other than the mid-range.
1
No, I can hook easily into my theater/music system with my current mp3 player. I will not buy a iPod either.
BobBart
1. 3 tv's one projector.
2. All sound like garbage.
3. 1 connected.
4. Yes.
O
offplaying
Contest Questions:
Contest Questions:
How many TVs do you have in your home?2
How many of them have crappy sound systems built-in?1
How many of them are connected to an external audio system?1
Do you own, or intend to buy, a stand-alone iPod speaker system?yes for outdoor listening
rlman41299
ans: 4 (1 led and 3 lcd)
all of them
2
yes ( own 2)
HiRez1394
How important is an external audio system, when your TV sounds crappy?
1. How many TVs do you have in your home? I have two TVs (one of which, an old standard-definition CRT, sorely needs to be upgraded/replaced to anchor a new AV system from scratch in a guest room).
2. How many of them have crappy sound systems built-in? I think both of my TVs have crappy sound, which is why I believe an external audio system is so important to integrate with a TV.
3. How many of them are connected to an external audio system? Both of my TVs are connected to an external audio system because their speakers are no substitute for a full-range surround system. If my old CRT TV gets moved to a guest room to make way for a new HDTV where the CRT sits now in my basement, then the guest room will need a compact and innovative all-in-one audio solution, given that the room does not have the space for a full-blown surround system based on six or more speakers.
4. Do you own, or intend to buy, a stand-alone iPod speaker system? I am thinking about an iPod speaker system or an iPod dock to use as an audio transport.
Tomorrow
Tomorrow
Contest Questions:
3
3
1
No.
purdaddy
purdaddy
ZVOX Give away entry
3 TVs
1 Front Projection LED - 55" Panasonic
1 Plasma - 48" Panasonic
1 13" DVD Combo Kids TV :eek:
and a 125" HT Screen & Sony Pearl Projector
All of the TVs have crappy built-in sound systems...
Just the theater setup....
We have a couple iPod speaker systems...
HtH (and I win ;) ),
-Patrick
Patrukas777
Patrukas777
I have 2 TV's.
1 of them
1 of them
I currently do not own one at this time, but I've been thinking about it for a while now. I normally just hook up my Ipod to my HT.
Monkeypimp
4. Do you own, or intend to buy, a stand-alone iPod speaker system? No
G
godan
2. How many of them have crappy sound systems built-in? 2
4. Do you own, or intend to buy, a stand-alone iPod speaker system? no
Status
