Hey guys, new guy around here, I've usually hung out more at avsforum but for some reason no one is talking about these speakers over there. So I'd been looking for some speakers to replace my current klipsch rvx-54's for a while. So even tho the wife wasn't excited about it, she didn't say no so i ordered the towers to start with and might do center and bookshelf surrounds soon as an xmas gift to myself
So today I'll be giving you guys my initial impressions from listening last night and today so far. Here's the setup I've got. It's a pretty big room, I think its 14x20 in my living room and opens directly into the foyer and makes an L all 10ft ceilings, so its alot of space. I've currently got a yamaha 1800 receiver powering my speakers and my xbox360 provides my music via toslink. The 360 streams it from my pc, all the music i've purchased in the last year or 2 i've encoded lossless, no mp3's here anymore. So its not a hifi system with a 3k cd player, but its what i've got and what I enjoy
Low end is anchored by a very capable epik valor 15" sealed sub. Lastly, of course are the klipsch rvx-54's, for those that aren't familiar, horn loaded and 4 5.25 cones in a slim aluminum enclosure and are super tall, lifestyle ish speakers.
Now i'm going to try to give you an unbiased post here without going into what i don't like about the 54's and stick with talking about the EMP's as much as I can. Let me first say that after turning off ypao(yamaha room correction), the 54's are much less tame beasts IMO. ypao really evened them out, and since I decided to listen to both for what they can do instead of what my receiver can fix, ypao had to go for my initial listening.
I started with 54's since those were already hooked up. Listened to them for about 10 mins with a couple different dave matthews band songs, the wife and i are pretty big fans and have most of his CD's. Then I hooked up the new EMP's. Sadly wife wouldn't let me get em more than about 12" from the wall. My initial first impression was HELLO MIDRANGE! And then hello base. I REALLY had to tone down the sub since the EMP's are less efficient and the sub was bumped up a few notches to keep up with the klipsch.
Getting more settled, I continued to listen as I could not believe the detail i was hearing in the midrange compared to the 54's. I really think that the 54's horn gives it just enough more db at the top that it makes it hard to hear the details of the midrange. The EMP's with the soft dome tweeter and dedicated midrange gave it much more detail in the mid and upper midrange. Sadly, i felt like the lower midrange was a little muddy and garbled at higher volumes, I played with crossover and some other settings and found they sounded best in my room crossed at 80hz, but i went back and forth on the small or large setting. I felt like i lost a little fullness set to small, but it got a little muddy set to large. Perhaps if I could pull em another 3-5 inches out it might clear them up a little bit. We'll see if I can inch em out over the next week or so
So overall i'm pretty impressed with their sound. The highs are maybe a touch recessed for my tastes, i'm sure ypao or even some manual adjustment could give em just a touch more volume. The cymbals and tambourines weren't nearly and prominent or crisp. Course listening to the klipsch's for the last 2 years maybe I'm just used to the big top end. But I was looking to get away from that and these are a pretty good change. I think I gained alot in midrange detail and lost the overpowering high's. Also since these can reach lower than the 54's, I can get off the 100hz crossover I needed to use for them. 100hz I could localize the sub somewhat and I wasn't a fan of that either.
I'll also comment on the construction a little bit to finish this post up. They come well packed, even though fedex COMPLETELY mangled one of them. The delivery guy helped me open it and inspect it but I couldn't find a scratch or dent on it and i looked over it for a good 10 mins I'd say. The layered foam inserts probably saved it from being a fedex claim. The red burl finish is very nice. I'm no expert on telling if its veneer or not, but it doesn't look like a repeat pattern on it, or if it is its large enough that it doesn't overlap in the same spots on the speakers. I read somewhere they're made of 1/2 mdf on the sides and doubled on the front. So they're not super heavy, and they aren't quite as inert as my epik valor sub enclosure, but I don't hold this against them in this price range at all. BUT, one thing I do hold against them is that there's no outrigger feet and the thinner profile and lighter weight makes them a little more wobbly than I'd like even with the spikes inserted. My thick carpet is not helping things either. Some feet off the back part could really help their stability IMO in case a child or pet pushes against them.
So overall fit and finish is very nice, the red burl is beautiful and a huge set up in looks over the klipsch which are sadly in silver. Sadly no pics, the wife left the camera at work
Hope you enjoyed it, man that got long! If you guys have questions i'll try to answer them the best I can.
