DVD & VHS combo for VHS transfer
maggie
I have been looking for a combo player to transfer 20 hours of home video vhs tapes to dvd formate. I was then going to keep the unit as my dvd player but none of the combo units seem to have dvd play back that is worth a crap; only good for the transfer of the tape. LG and Panasonic are highly regarded for their transfer capabilities.
So I had another thought;
1. transfer the tapes via cables from my "old" vhs machine to a new dvd player/recorder. This way I should be able to upgrade my dvd player and avoid the negatives I stated above about crappy DVD playback. Would this work and which player would you recomend?
2. other thoughts.
Thanks
Maggie
AUtiger
AUtiger
I'm in the process of doing the same thing. I haven't produced any results yet, but I'm following the same line of thought. You can't upgrade the quality of the tape; therefore, I looked for a DVR that got decent reviews and wasn't expensive. I got a panasonic ES20 off Ebay for less than half of retail. The kids are using it in their room. Hope this helps.
