I have ported Standmounts rated to about that...
That tends to be the low end extension of many commonly available speakers. Many, unfortunately, roll off higher... some much more.
For most conventional Music, that is enough to cover almost everything except the bottom keys of a Piano and the lower end of Pipe Organs.
It's not enough for HT LFE content, though, which should always be supplemented by a capable Sub!
I would argue that the minimum extension one should seek is ~18Hz. But if you want to chase the 32' Stop on a Proper Organ, you need to dig down to 15-16Hz.
What Towers do you have?
