What are the differences, similarities, and why should I choose one over the other?
J Joseman37 Audioholic Intern Mar 5, 2020 #1 What are the differences, similarities, and why should I choose one over the other?
lovinthehd Audioholic Jedi Mar 5, 2020 #2 A soundtrack will be encoded with one or the other usually, more a way to reduce file size, the basic lossy versions or even the lossless versions. Or are you talking about a sound mode/upmixer on your avr?
J Joseman37 Audioholic Intern Mar 5, 2020 #3 lovinthehd said: A soundtrack will be encoded with one or the other usually, more a way to reduce file size, the basic lossy versions or even the lossless versions. Or are you talking about a sound mode/upmixer on your avr? Click to expand... I don't know what sound mode/upmixer means.
lovinthehd Audioholic Jedi Mar 5, 2020 #4 Joseman37 said: I don't know what sound mode/upmixer means. Click to expand... I don't know what you mean particularly by choosing one or the other, unless it is a sound mode/upmixer on your avr rather than selecting soundtracks based on the codec they're using. It can be confusing as they share the same brand names. What avr do you have? I assume it has sound modes/mixers labeled Dolby PLIIx or Dolby Surround or DTS Neo:6 or Neo:X etc. and you're asking which you should use. The short answer is what you prefer. Both have their own dsp flavor and can upmix from 2.0 to surround modes....
J Joseman37 Audioholic Intern Mar 5, 2020 #5 lovinthehd said: I don't know what you mean particularly by choosing one or the other, unless it is a sound mode/upmixer on your avr rather than selecting soundtracks based on the codec they're using. It can be confusing as they share the same brand names. What avr do you have? I assume it has sound modes/mixers labeled Dolby PLIIx or Dolby Surround or DTS Neo:6 or Neo:X etc. and you're asking which you should use. The short answer is what you prefer. Both have their own dsp flavor and can upmix from 2.0 to surround modes.... Click to expand... Denon AVR-S640H
lovinthehd Audioholic Jedi Mar 5, 2020 #6 Joseman37 said: Denon AVR-S640H Click to expand... The sound mode possibilites start on page 90 of the manual....
mtrycrafts Seriously, I have no life. Mar 5, 2020 #7 Select one that is on the media. If both are there, flip a coin. Problem solved. Don't agonize over this.
