Does optical cable brand matter?
Status
Not open for further replies.
NINaudio
NINaudio
Yeah I might return my regular monoprice Ethernet cable anyways it doesn’t seem any quicker then my no branded cable . I could try the $13 cable it seems higher popularity then any others I linked . The $10 one looks second best .
The speed of your internet connection is not going to change based on your ethernet cable. o_O
As for optical cables, just pick one, this is not a decision that needs agonizing over.
Kingnoob
Kingnoob
Yeah this one is almost $5 cheaper then either of the $12 one I wanted does a thicker cable last longer?? I’m probably using it until the avr dies and I need a hdmi one.
Help me decide on this product: Monoprice 12ft Optical Toslink 5.0mm OD Audio Cable https://a.co/d/bFO54JZ
better looking cable
Help me decide on this product: TOSLINK cable, optical audio cable – 15 feet fiber optic cable for soundbars (TOSLINK to TOSLINK, digital S/PDIF cable, stereo systems/amplifiers/amps, home cinema, Xbox One/PS5) – CableDirect https://a.co/d/hnprTX1
NINaudio
NINaudio
Well, it matters whose ba
I always get a kick out 24k gold plated optical cables. The plating does absolutely nothing for this type of signal transfer except add to the cost and maybe add some visual appeal.
You just said everything that is added. :D
OP, you asked if the brand matters. Of course it matters to the company that sells it. :D
Kingnoob
Kingnoob
ahh I see lol
Basically just pick one thick enough the cat won’t think it’s a headphone wire and chew the hell out of it lol :D
monorprice jacketed vs this cable ?
NINaudio
NINaudio
FFS. :rolleyes:
Stop asking and pick one, or both, I don't care, and send one back. You could have had them both in hand at this point, decided which one you think your cat wouldn't chew, and sent the other one back on it's way already.
Status
