The fans in most H/K receivers will only kick on when the internal unit reaches a 'critical' temperature. It's an emergency measure incase you stack components on top/below your HK so it doesn't overheat and go nuclear.
The only active fans in HK units are in the 635 and 7300 unit, which is actively cooling the video processing unit (FLI-2300 in the AVR7300), which generates as much heat as a low end computer CPU.
In most cases, the massive aluminum heat sinks are able dissipate the heat without assistance.
