Like itschris, I have/had several 2 channel amps and did an inhouse comparison to decide which I preferred and which I would keep. A Carver TFM35, and Adcom 555 and a Luxman M-117. The Carver by far is the most laid back and "liquid" is a very apt adjective for what it does to the midrange, vocals with a hint of softness to percussive strikes and cymbals. The Adcom was neutral, accurate and in your face. I really liked the difference, but ultimately I couldn't make it play nice with the Carver. It was ok on the fronts with the Carver on the surrounds, but not vice versa. It stood out in surround duties and took you out of the moment. The Luxman has elements of both amps. By far the best bass punch, a very smooth midrange with laid back highs. It's similar to the Carver sound, but different. I use it for my fronts and put the Carver on the surrounds, for now. It is interchangeable and I can mix it up anytime without a loss of synergy. As stated, Bob Carver emulated/modded many of his Carver and Sunfire amps and markets a "tubelike" sound. You either love it or hate it. Luxman did similar modification though the Carver is a transfer function Class H and Luxman a class A/B. Some might find the differences subtle, but I found them fairly stark and easy to assign preference. I also have no interest in DBX testing or creating any sort of scientific evaluation. I just plug it in, set the gain to max on the amp, calibrate, listen and let my speakers tell me what I'm hearing. I'm sure there are many amps that are more similar than different, but these particular amps, IME, have easily apparent sound signatures.
