Do I need a dedicated cd player
  • Thread starter DACunknownthing
  • Start date
DACunknownthing
Hello all, new to this site so please bare with me. I am wondering if I would get good audio on cds if I kept my LG BD390 bd player, or used my old Kenwood DP-1520. Should I use this old stuff for music or buy a new bd, or cd, or combined player? It will all be connected to a Yamaha RXA3080. Thank you for any help and advice.
Verdinut
Verdinut
You would get good audio CD playback with your LG BD390, and you don't have to get a replacement. A good blu-ray player will perform better than any CD player.
You're fine with the current player. It's just acting as transport and a capable one....most of the time you see chasing dedicated cd players it's for the onboard dac as they're connecting it to old analog only 2 ch gear....altho there is something to be said for old cd players as far as ease of using front panel instead of a gui via your display....
slipperybidness
slipperybidness
This right here!
A dedicated CD player is more about ergonomics and ease of use than anything. I personally prefer a tray-load vs. slot-load disc drive.
BD players can be awkward to use to play a CD without a TV in the system, so a CD player can make more sense in that system.
This right here!
OTOH if all you need do is play you can usually set the bd player to play a disc upon loading....but if you want to set random/repeat or a particular track, that sort of thing, you need the display IME.
Mark of Cenla
I bought a very small video screen from Amazon for about $40 so that I can see the tracks when I use DVD and Blu-ray players to play CD's. It was well worth the money. Peace and goodwill.
Bobby Bass
Bobby Bass
Are you happy with how your 2 players sound now? If not, Not sure what your budget is but there are a lot of used ones available with people moving from CDs to streaming.
Mark of Cenla
Yes I run them through Prozor DAC's. The Philips sounds a little better than the SONY. But the SONY has more information on the video screen. Peace and goodwill.
1
1MoreFord
Could you give us a link to the type of screen you're talking about?
TIA
Mark of Cenla
TIA
I went to Amazon.com and searched for a small video screen. There were many, and I bought one called Eyoyo. Peace and goodwill.
