Hello. First time poster. I read this article on the Audiophiles On A Budget facebook group and registered to share my experiences as a neophyte speaker builder.
A few months ago I started reading about speaker building. It started with an article on transmission line speakers, which led me around the internet until I found both WinISD and Leonard Audio's Transmission Line software. I spent weeks typing in the TS parameters of the various drivers available from Parts Express and playing with enclosure designs, just working the software, before I finally decided on a project.
I decided to build a pair of desktop computer speakers using a pair of single full-range drivers. I chose a pair of Dayton Audio (Parts Express's house brand) RS100-8 4" drivers. My main considerations were:
1) I wanted single full-range drivers. This would allow me to focus entirely on the cabinet enclosure and eliminate all of the multiple variables coming from multiple drivers and crossovers. I was very interested in accurate stereo imaging and single full-range drivers seemed like the best method of achieving that.
2) These drivers are affordable (I paid $25.00 each on sale) and with 18 reviews, 22 questions and 46 answers on the Parts Express web site, they are quite popular and well received.
3) Computer modelling indicated that I would be able to build the speaker cabinets small enough to fit nicely on my computer desk on either side of my monitor.
I went ahead and built them, following the WinISD recommendations for enclosure volume and port dimensions. I first did a test build using a raw plywood enclosure and PVC pipe for the port, and when I hooked them up and gave them a test drive, I was really thrilled to realize that what I had built on my first try totally blew away the computer speakers that I had considered "just fine" right up to that point. As many of the reviews warned, these drivers are bass shy -- they roll off around 100 Hz. The reviewers recommend a subwoofer. Instead I put a second pair of speakers on the back wall of the room to fill in the bass, which worked quite nicely.
I then turned my attention to building a nice pair of cabinets to replace the rough plywood cabinets. I slanted the front surface of the speakers to match the angle on my monitor, replaced the round port with a rectangular slot port at the bottom of the cabinet, and used MDF instead of plywood. I've since veneered the front faces of the cabinets and intend to get around to the sides and top as time allows.
Are my speakers better than $1000 speakers? Probably not. But I put $50 in parts into them (plus my labor, but I got the MDF for free.) Are my speakers better than a pair of $50 computer speakers? Oh heck yes. I'm completely happy with them. Everyone who listens to them wants a pair for themselves. I could probably start building and selling these little speakers and maybe I should.
I certainly don't have years of experience and dozens of designs under my belt. What I did discover was that the combination of:
1) The availability of high quality speaker drivers with published TS parameters, and
2) The availability of good speaker design software like WinISD and Transmission Line
has opened the door to amateurs like myself being able to successfully design speakers that perform the way they were designed to perform.
But all is not wine and roses. Since then, I've tried two additional builds, each of which surprised me.
Soon after describing my results, someone recommended that I try a transmission line enclosure based on the TABAQ design, but using the same RS100-8 drivers. I modeled the cabinets in Transmission Line and built them out of MDF. While they did seem to offer a certain amount of bass extension over and beyond the bass reflex design, they also seemed to introduce comb-filter like artifacts into the midrange that made them unpleasant to listen to. So I considered that attempt a failure. But the drivers went right back into my desktop speakers, so it didn't cost me anything beyond my time. (once again, the MDF was free.)
My third design was a pair of bass reflex speakers designed around the Tang Band W6-2144 6.5" full range drivers. After the RS100-8 experience, I was specifically looking for some deep bass, and these drivers were advertised as reaching 45 Hz. I went ahead and did a ported cabinet in (free) particleboard, as recommended by the WinISD software. The cabinets wound up being rather bulky -- with a 1.9 CF volume -- and unfortunately the results were mixed. I modeled them for flat frequency response -- and what I got were speakers with terrific bass. And I don't mean one note bass either. My test track for deep bass is Bela Fleck's "The Flight Of The Cosmic Hippo." The overpowering bass on this track comes out as both melodic and smooth, and you can feel it in your chest. Same thing for the heartbeat at the beginning of Dark Side Of The Moon. Unfortunately, the midrange and treble are harsh and unnatural and not pleasant to listen to, and it sounds like there's a hole in the low midrange. A second unsuccessful build, although at this point I really don't know why.
So at this point I feel like I can't really go any further without a USB test microphone to quantify the problems I encountered. The process of building a pair of simple test speaker cabinets involves about 4 hours of woodworking, and it seems foolish to approach the problem blindly. I am also quite aware that once you get away from single driver speakers with sealed or simple bass reflex cabinets, things start to quickly get complex. Multiple drivers, crossovers, tuned enclosures -- all introduce multiple interrelated variables and this is of course where experience starts to really matter. This is why I haven't gone there yet.
However, I am convinced from my experience that an amateur, armed with the resources available online, a thoughtfully selected pair of full range drivers from a DIY retailer like Parts Express, WinISD or other design software and some moderate woodworking skills can definitely build a pair of very good single-driver sealed or bass reflex speakers that will stand up favorably to the equivalent professionally designed product.
Beyond that, your results will likely be commensurate with your actual experience and understanding of what you are doing. Just like everything else worth doing! A beginner CAN approach speaker building in a logical way and achieve good results, as long as they are sensitive to understanding what they do and don't know and keep their variables limited and under control.
