If you really look at the original poster's comments I get the impression that (1) He does not want to have to spend more money to replace his subs, that he's looking for a working solution that won't cost him money, as he laments already spending around $5,000 (2) I didn't read where he exactly said he's looking for more output, greater extension, or a smoother frequency response.
Some things I took away from the OP
I am trying to maximize the bass in my HT. I have read thru numerous articles and blogs regarding sub placement, acoustics and basics of how they operate. I find myself just getting bogged down with all the technical minusia.
He is obliviously working hard to enjoy his HT and get the most out of his purchases I have a considerable amount of money invested and although I am happy with the overall performance I think for the money I spent the bass
response is surely lacking.
He would certainly like more than he is getting I have moved my subs to all the possible locations ran the Audyssey and in all honesty I am hard pressed to tell the difference.
He has most likely ruled out a null Maybe it's a limitation of my subs or placement. Maybe I am just expecting to much from a home system that cost under $5000. I don't know. My subs are currently opposite corner loaded. My HT room is 23x19 with 8ft ceiling. The room is fully carpeted with soft blind material on the windows and a large L shaped couch. I think the room acoustics are better then what most people have to work with. Although he isnt in a dedicated room,
his room dosent seem to be his issue I am running Aperion Grand speakers with two Aperion Bravus II 10D subs. Marantz SR 6007 and Emotiva XPA 3. And a Oppo BD 103 BlueRay Player. Are there any suggestions on how to increase the bass without replacing equipment.
He hopes he has missed a step in his setup
The most important thing from the above is: Are there any suggestions on how to increase the bass without replacing equipment? Unfortunately the answer is no. Even if he tweaks every last bit out his subs, he still would be dissatisfied. For the money he spent on them for the performance isnt a high value. We have all made purchases that we expected more performance for the price we paid. He will be fine after an upgrade, which i see no where in the OP that states I will not upgrade
From Gene's review
"The 10D appears to have usable bass extension down to around 30Hz though don't expect much SPL at those frequencies. Below 30Hz the output is dominated by 2nd harmonic distortion. Trying to get this sub to play usable bass below 30Hz at meaningful SPL levels is like expecting Sarah Palin to actually be funny doing stand up comedy or Obama to grow balls and actually make good on his promises. "
