No, there are no harmonics. Yes, it is supposed to be straight up but it doesn't matter. It is about timing between pulses and the width, I believe, not that it goes up or not. A good digital handbook will explain it.
Therefore, certain frequencies, based on the construction of the cable, could lose a lot of integrity over the length of the cable.
Not at these frequencies and if it is a 75 ohm cable, it works, period. But, in home applications where the cable is so short, it doesn't matter much
Therefore its not like you will result in all 0.9s and 0s instead of 1s and zeroes. You may actually get a 1 where there is supposed to be a zero, or vice versa.
Nope, not the case.
Furthermore, I have read someone say that coat hangers could be used if you could block unwanted outside emissions. Well if you have too much distance between your signal line and your return line, in other words you just hold the 2 coat hangers apart so they don't touch, you end up with parasitic inductance. Which, especially for high frequencies, results in impedance and therefore signal degredation.
Could be wrong who knows....
We know. Coat hangers work for short distances of home audio. It is just not practical.
