Digital Coaxial vs. RCA
Greetings all,
I have just finished reading this thread and thought I might offer my two bobs worth, just incase any one may be interested.
It seems to me that some sound like they know what they are on about, and others are new to the whole audio thing, either way, we should never be too old to learn new things.
The other thing, if any out there is like me, we like to know why or why not, not just what will or won't work. So here's some thoughts for you to ponder.
The first point that needs to be made is that the RCA in RCA cable refers to the connectors at the end, NOT the cable.
Second, the Digital in Digital Coaxial Cable is kind of pointless and more of a sales feature than anything of real use. Why? Quite simply, any cable can handle a digital signal. In simple terms, this digital signal is required by a digital amplifer to tell it where to send the sounds. The digital signal comes from the digital output from your digital source (dvd player for example). The old analogue signal system, uses a voltage running through the cable and varies the strength or power of that voltage. With digital, the voltage is either on or off (albeit many thousands even millions of times a second). In both cases, the same cable can handle either signal. So whether it is a $100 yoo bewt special doo dah cable or a coat hanger. In basic principle it doesn't matter. The digital signal from the dvd player will get to the digital amp so long as there is a connection between the two.
Three, the Coaxial bit in Coaxial cable refers to the type of actual cable used. If you look at the rear of your dvd player or amp, if there is a coaxial connector on the back, there is a good chance it will have COAXIAL printed either above or below the connector. This is printed there for a reason. It is to tell the user that a coaxial cable is the preferred cable type. Note that I did not say ONLY cable type. As mentioned before, in basic principle, a coat hanger will infact pass the signal from one to the other. A proper coaxial cable how ever will do it much better, and by better I am referring to signal quality.
For an exploded diagram of a coax cable go here:
http://searchnetworking.techtarget.com/sDefinition/0,,sid7_gci344289,00.html
For an excellent description go here:
http://en.wikipedia.org/wiki/Coax
The main reason for using coax cable is because of the cables ability to block anything that may interfere with the signal between the two units and degrade it some how. This interference can be caused by simply running your signal cable next to the power cables of the same devices. By nature, power cables radiate their own signal, this radiated signal can interfere with the signal running from your dvd player to amplifier, and will in many cases cause that signal to be of lesser quality than it should be. This in turn could cause your amplifer to send the wrong sound to the wrong speaker, could caused a crackling, hissing or humming sound, or simply just not sound quite right. Or you may not hear anything at all. It should be noted that this interference is more typical in longer cables of say 3 metres and up.
So, should you spend the $$$'s on a yoo-bewt sooped up cable? No. not necessarily. But ask yourself this, why did you by a digital surround amplifier and dvd player? If you're like me, it's so you can experience the awesomeness of home theatre. True? If yes, then either buy or make your own cable that has rca connectors (plugs) at the ends, so you can connect it to your dvd players and amps connections and use some type of reasonable (not soopa doopa) quality coax for the cable, to stop the signal from being interfered with from outside sources. Give your senses the best chance of experiencing home theatre the way it should sound.
It is important to note that RCA type cables are not always made with coax quality cable, double check for yourself or get the sales person to show you.
Oh, and as for gold connectors, don't waste your money, it's just a wank factor that you don't need. You nor I will tell the difference between gold connectors and plain ones.
I hope I didn't waffle on too much and you have more of an idea of why the correct cable is important. Correct cable doesn't mean $$$'s, it just means correct specs. RCA connectors (plugs) and coax cable.
Happy home theatre-ing to all.
Keep it real.
