What about the
$550 Outlaw pre-pro in the same magazine that has a Crosstalk of -93dB & SNR of -121dB? How is that possible for $550?
"There was no multichannel input to measure. The analog THD+N was less than 0.020% at 1 kHz with a 100-millivolt input and the volume control set to -09 dB. Crosstalk with a 100-mV input was –91.28 dB left to right and –93.81 dB right to left. The signal-to-noise ratio with “A” weighting was –121.85 dBrA."
Wait, how did I miss this? The
$600 Emotiva pre-pro has even better measurements than the $10,000 Bryston:
Emotiva UMC-200 Preamp/Processor HT Labs Measures | Home Theater
"Response from the multichannel input to the main output measures –0.20 dB at 10 Hz, –0.05 dB at 20 Hz, –0.02 dB at 20 kHz, and –0.12 dB at 50 kHz. The analog THD+N was less than 0.016 percent at 1 kHz with a 100-millivolt input and the volume control set to 65.5. Crosstalk with a 100-mV input was –93.91 dB left to right and –92.23 dB right to left. The signal-to-noise ratio with “A” weighting was –127.94 dBrA."
$1800 Sherbourn pre-pro:
Sherbourn PT-7030 Surround Processor & PA 7-350 Amplifier HT Labs Measures | Home Theater
"Response from the multichannel input to the main output measures –0.17 dB at 10 Hz, –0.05 dB at 20 Hz, –0.09 dB at 20 kHz, and –0.54 dB at 50 kHz. The analog THD+N was less than 0.032 percent at 1 kHz with a 100-millivolt input and the volume control set to 84. Crosstalk with a 100-mV input was –80.56 dB left to right and –78.94 dB right to left. The signal-to-noise ratio with “A” weighting was –118.88 dBrA."
$10,000 Bryston SP3:
Bryston SP3 Surround Processor and 9B SST² Amplifier HT Labs Measures | Home Theater
"Response from the multichannel input to the main output measures –0.05 dB at 10 Hz, –0.01 dB at 20 Hz, –0.06 dB at 20 kHz, and –0.42 dB at 50 kHz. The analog THD+N was less than 0.022 percent at 1 kHz with a 100-millivolt input and the volume control set to +2.5. Crosstalk with a 100-mV input was –92.92 dB left to right and –93.44 dB right to left. The signal-to-noise ratio with “A” weighting was –121.59 dBrA."
