shadyJ
Speaker of the House
Staff member
It all depends. Music is transient in nature. The power supply caps handle a lot of peak power demands. Unless someone listens to music with a limited dynamic range on the "All Channel stereo" setting, even with a subwoofer the possibility of tripping a circuit breaker is remote IMO. It would be different with a circuit protected by a fuse. Circuit breakers can handle overloads for several seconds before tripping.
All true, but nonetheless, I would not want to use an AVR like that on the same circuit as another power hog.
RedCharles
I was reading Gene's review, and he wrote that it could draw 25amps using all 10 channels at 170w. Basically, he was saying that it can overpower a typical 15a circuit. So I can totally see what shadyJ is talking about.
As I read Gene's review, I also learned that this thing is a space heater.
I'm going to have to take that into consideration.
You will never run all 10 channels at 170 W unless you use the amp to power a resistor bank instead of real loudspeakers and listen to music. A 20 A dedicated line for that amp is a good idea regardless.
Likely you're not going to use it full power ACD to pull that much power....or maybe you will :). An external fan might be a good idea, tho....
RedCharles
I don't like to listen to music that loud. Getting this receiver is more akin to uhhh...uhhh...
Verdinut
Verdinut
If you don't listen to music that loud, then you most likely won't need a dedicated 20 amp circuit, unless you have other equipment on the same line that draws a lot of current, such as an old plasma TV which could easily draw 500 watts.
For example, with my 7 channel HT system, I use external amplification for all channels. The total rated output power of the 10 amps exceeds 1900 watts. On the same 15 amp circuit, a 12 year old plasma Panasonic TV continuously draws 400-500 watts and I have never seen the lights which also are on the same circuit dim when I play music. The maximum SPL in my case is 88-90dB.
I suggest that you verify this link with which you will find how much power you need to drive your speakers to the maximum desired SPL:
K
Kleinst
Do you have one or is there a 5805 available nearby? I sure as hell wouldn't spend what I see them costing on EBAY, you could get a Denon AVR with a Monolith for that price
RedCharles
I've seen them on ebay for around $700.
RedCharles
I read your review closely, and saw that while the 5805 is arguably the greatest receiver of all time, it is a space heater, and decided against it.
I ended up getting a Pioneer SC-09. I read your review of the SC-07 and saw that the ICE amps have questionable handling of 4 ohm loads, but I read a lot in a owner's forum of the SC 09, and they seemed fine running the SC 09 with demanding 4 ohm speakers. So I took a chance. It felt good to be bad. And I've got to say the SC-09 is a huge improvement over my dying 94TXH. I didn't know I was listening to music through a wall of mud until I got the SC 09 hooked up. Very happy.
