I don't believe the 160m has an anechoic sensitivity of 92 dB. If you have a multimeter and an SPL meter, you can test it to see if it matches Klipsch's specs. I would guess its sensitivity is in the upper 80s.
I don't have a multimeter that does true rms. I know the RP-150m measured 88dB from S&V, and when I replaced those with the 160ms, audyssey brought the trim down about 3dB, so I'd guess that's close to 91dB.
Could a regular rms multimeter work at all? It'd be nice to get a real in room sensitivity rating for my own purposes. As most of you know, I regularly watch movies at reference level, and probably do use a good deal of power to do so.
Sent from my LM-X210(G) using Tapatalk
