Deal Alert: Toshiba 42HP83P 42-Inch Plasma Display $2999
The prices just keep dropping... OneCall has the Toshiba 42HP83P 42" HDTV Plasma Display for only $2999.88 after $500 mail-in rebate! Ships for as low as $191.74. Lowest Price Search yields $3611! This unit features 1024 x 768 True HDTV resolution (720p) and CrystalScan HDSC which upconverts all incoming video signals (including 480i/p) to 1080i HD:
HD Window Multi-Scan 2-tuner POP now accepts 480i, 480p, 720p, and 1080i signals and can even display 2 different resolution signals at the same time.
Split-screen function allowing you to adjust the size of the POP boxes as well as display 16:9 and 4:3 images on the screen at the same time.
7 MultiWindow system allows you to view the main picture while viewing your favorites or doing a channel scan in the 7 smaller boxes.
Direct Video Input Selection - Inputs can now be directly selected from the remote's numbered keypad without scrolling through all the inputs (great for users of custom remote controls).
Includes tabletop stand​
Get the Deal!
