I think these would perform a lot better with a good xover mod. The lack of a low pass and a lousy first order high pass causes extremely poor off axis response. I'm not sure where the AMT tweeters fs lies but a 4.5khz xover is just way too high for a 6.5" driver, especially considering there's two of them. Secondly, they're way too short unless you're sitting on the floor. Couple of cinder blocks should help.
Sent from my LM-X210(G) using Tapatalk
It's not the Fs that would be a problem, as most AMT tweeters do not have a well-defined resonance peak like traditional voice-coil/suspension based drivers. They are for the most part purely resistive, with perhaps just a teensy weeeeensy resonance spike.
This is the impedance plot of the Beyma TPL-150H, as an example. Even on a hugely magnified scale, one can just barely make out that tiny bump. About the size of the belly of a pregnant mosquito, lol.
The issue would lie, IMO, simply with the "low end" capability of such a small tweeter. Yes AMT tweeters have a lot of surface area, but it's folded, so it is still limited by the area of the actual aperture.
I would be willing to bet that those AMT's from the Air series are in fact Hygeia-based units, with different face-plates, similar to the RT-20051's that I ordered direct from them not too long ago:
AMT MADNESS !!!!!
The actual size is 11/16" square, not even 3/4". Again, this is my AMT RT-20051 tweeter that I
believe is identical to the Dayton AMT in the Air speakers.
This is the actual impedance plot of my AMT. Resonance peak is so tiny, my DATS doesn't even pick it up to define a Q for it:
But on the good news side of things, AMT's do respond nicely (IMO) to horn loading to extend the low-end. Perhaps some of you might be ambitious enough to experiment with them as I did
This is baseline curves + horn-loaded FR curves for Airborne (Hygeia) RT-50021. Blue & green curves are stock baseline curves, Red & purple depict the tweeters mounted on a modified Parts Express H-110 horn for experimentation.
With the proper horn geometry and aperture loading, I would be willing to bet those tiny AMTs can have their low-end response extended down closer to 2.5 kHz, maybe even a little lower.
