DACs; quality and sound
awdio
Ratings
4 6
No, actually the Denon 3808 & 4308 have the Burr-Brown PCM 1791, which is Third in line. The Numbering system is messed up: #1 is PCM-1792, #2 is 1796, #3 is 1791.
The Denon 2808 has PCM-1803, which is further down the road.
So, the ultimate Burr-Brown DAC is the 1792 (only found in the $3,800 DVD-5910 SACD/DVD-Audio-Video player).
The #2 DAC is the 1796, which is in the $7,000 AVP-A1 pre-pro, $5,200 AVR-5308 receiver, $2,000 DVD-3800BD blu-ray, & $1,500 DVD-3930 (& DVD-3910) SACD/DVD-A-V.
I have to wonder why they would put the #2 DAC in the $7,000 AVP-A1 pre-pro, but put the #1 DAC in the $3,800 DVD player???:confused:
Because you are wrong. Yes I know this is an old thread but dislike inaccuracy so future readers will not continue this inaccuracy. Both components mentioned have the same Burr Brown 1792 DACs.
Ratings
5,526 9 1
That is false. ADTG is right, the avr-3808/4308 (own one) have the PCM1791. Download their product sheets to see it for yourself.
awdio
Ratings
4 6
If it helps, our group was unable to find an audible difference between any two DAC's or CD players manufactured after about 1990, regardless of the DAC chip used or the manufacturer or price of units involved. We couldn't get a statistically meaningful audible difference between a $3500 CD player with a 24 bit DAC and a $120 portable CD player with a 1 bit DAC. They all sounded the same in bias controlled listening tests. So I wouldn't spend a second worrying about the brand of chip used in a player or receiver. It is all marketing.
This just isn't true. If you look at the EAD DAC series 1 and the series 2, the only difference was the DAC chip. They went from an Analog Devices to a Burr Brown and the sound between the two was night and day. Perhaps you need to change the date that you think DAC chips sound the same. It definitely is not 1991.
awdio
Ratings
4 6
No you are confused to what I referred . The AVP A1HD and the Denon 5910 both have the 1792. He said the AVP had the 1796.
awdio
Ratings
4 6
FYI I also own both and have in the past corrected Gene for making this same mistake which he corrected in his reply to me.
Ratings
8,000 23 6
From Gene's review of the AVP-A1HDCI:
https://www.audioholics.com/av-preamp-processor-reviews/denon-avp-a1hdci/design-overview
"the AVP-A1HDCI uses the very best Burr Brown PCM-1796 dual differential DAC’s (four per channel),coupled with Denon’s own proprietary DDSC-HD digital audio technology and Advanced AL24 processing for the highest linearity and lowest noise floor possible."
So if I made a typo 11 FREAKING YEARS AGO, it was based on the 11 YEAR OLD AH review.
So chill out. Geez.
Ratings
8,000 23 6
Wow. So proud of yourself for correcting an 11 YEAR typo.
Yeah I also used to own both the Denon 5910 and AVP-A1HDCI. Sold the Denon 5910 because it didn't sound any better than my cheap DVD player. The AVP-A1HDCI died 8 years after I bought it brand new.
So don't act like you're the only one around here who has owned a few components. :D
Wait another 11 years before you respond to this one. Geez. :rolleyes:
Ratings
5,526 9 1
I am not confused, your post#103 was misleading, but thanks for clarifying which two components you actually referred to.
Ratings
5,526 9 1
I agree with his point about accuracy, perhaps his tone could be better, such as allowing for the "typo" possibily, but we all have different styles..
Ratings
8,000 23 6
Never wrong to correct any typos for sure.
And acts like nobody around here has owned ooh "high-end" components. Ooh Ahh so impressive. :D
Ratings
5,526 9 1
I don't know, if you live in the North pole, on a nice summer day, night and day may not be all that different depending on the hours you pick.
Ratings
8,000 23 6
Oh it’s that the vampire movie “30 Days of Night”? :D
Then night and day would be the same. :D
