CSS DIY Sub - Tips/Advice please!
caper26
caper26
Here is the Build Thread
What issues did you run into? Are you gonna take some in-room FR measurements?
Yeah I will take some measurements when I get a meter. I found one on ebay but got busy building the sub and forgot when it ended :(
Issues:
  • I should have made the double layer front panel slightly larger and sanded it down after assembly since it is hard to clamp it perfectly square.
  • The Duratex stuff is weird if you haven't used it before. I had to experiment with different rollers, etc...PITA.
  • Besides that, I had a few equipment issues (factory defect, resolved) and some amp hum, blah blah, that I have to work out still...
