You're welcome! Good timing... I just logged on!
It's just a sum of the drivers used, not that a speaker is designed in such a way.
Impedance is the measure of opposition a circuit provides when voltage is applied. It is similar to resistance, but in an AC circuit, impedance includes both magnitude AND phase. Which also means it is constantly variable, so the number printed on the back is typically the lowest impedance the speaker provides.
So when dealing with LOWER impedance speakers, such as 4 ohms, there is little opposition to the voltage, so the speaker will willingly take whatever an amplifier will give it. And with lower end receiver amps, this can be a very bad thing. A warm receiver is normal, a HOT receiver needs to be shut down immediately!
