Choose a Denon Preset & Audessy 500hz Curtain & Hidden Field
Mike Green9
Hi.
I have run the Audessy X32 Android App and dowloaded 2 files (Preset 1 & 2) to my Denon AVR-X3800h.
Denon Question:
1. I would like to try each Preset - how can I switch between Presets, and how to go back to the original settings (not use either Preset) ?
Audessy Questions:
2. I know I can Edit a file, but I can't figure out how to make a 500hz Curtain ??
3. I tried to Email a File, but when I attempt to fill in the "TO:", the keyboard that pops up hides the Field so I have to type it in 'blind'. Is this a bug, and is there a workaround ?
Thanks,
M....
William Lemmerhirt
William Lemmerhirt
Hi.
Denon Question:
Audessy Questions:
Thanks,
M....
1. Go to the apps home page and select which profile to load. Hit the share button(on mine it’s a box with an arrow) and send to receiver.
2. When you select a profile you will see different options. Look for the “frequency range” option. After you select that, it will bring you to the actual graph. Just grab the slider and move it to wherever you want to cut it off. Then send to the AVR, or save or whatever.
3. Not sure. Maybe share a screenshot? We might see a button or something not obvious.
Mike Green9
Hi and thanks for the prompt response.
Are you saying the only way to select a profile is through the App ??
I was kind of hoping I could switch back and forth on the Denon and try to hear the difference right away. Sort of like an A B switch.
Okay - the 'frequency range' option. Seems obvious now.
I will take a screen shot of the keyboard hiding the "TO" field, and the new Audessy profile later today. The Before and After smoothing of the curve is dramatic. Audessy rocks!
Thanks,
M...
Mike Green9
Hi.
Attached is a pic of the keyboard partially hiding the "TO:" field when I try to Send a file in Audessy. Not a big deal, just annoying. Pardon my poor photography.
Thanks,
M...
E
ElizabethRAllred
