Pedro Alvarado Full Audioholic Jun 12, 2017 300 0 18 Oct 8, 2017 #1 i can't seem to find a stand i want. a couple of days of searches lead me to the attached pic, which is similar to what i need. this stand in the pic is made by bang and olufsen. their stand bolts to the speaker at the top and adjusts from the middle. i'm looking for one that has a shelf to put a center channel on top and title up, or down. i haven't seen any on the diy area and decided to post this in hopes of finding just the right one.
R roadrune Audioholic Mar 20, 2016 143 0 28 49 Oct 8, 2017 #3 Why do you need an adjustable stand? Cant you use a chair and som books or whatever to find the righe angle, then build a fixed one? Reactions: Pedro Alvarado
Pedro Alvarado Full Audioholic Jun 12, 2017 300 0 18 Oct 22, 2017 #4 because I don't want to look at a chair with books or whatever
R roadrune Audioholic Mar 20, 2016 143 0 28 49 Oct 22, 2017 #5 I ment that you use the chair to find out how a fixed stand need to look like, not that you should use a chair as a permanent stand.
mtrycrafts Seriously, I have no life. Aug 19, 2004 23,551 0 113 Oct 22, 2017 #6 This is how I solved my tilted center stand need. Reactions: MrBoat, Kev Greenhalgh and lovinthehd
Pedro Alvarado Full Audioholic Jun 12, 2017 300 0 18 Oct 22, 2017 #7 mtrycrafts, now that is trick man!
agarwalro Audioholic Ninja Jan 31, 2005 4,320 0 113 Pittsburgh, PA Oct 23, 2017 #8 Door stops on a regular stand? Reactions: Pedro Alvarado
j_garcia Audioholic Jedi Jul 11, 2005 32,533 0 113 Oct 25, 2017 #9 I've seen plenty of center stands, but none that offer tilt directly - the majority will have adjustable feet that would allow you to adjust tilt a bit. MoPads or similar will also give you a few degrees of adjustment on any shelf/stand.
