Rob Babcock said:
Yeah, certainly S/N-wise Redbook is sufficient. I'd really be interested to do a compro with Redbook vs DSD.
It would be intersting to see a scientifcally valid test, but no one has motivation to do this. Sony knows the results of the peer reviewed perceptual studies on these matters.....
I'll certainly agree with you when you say hard to discern. But in this instance, I'd welcome your customary blizzard of links about one subject: DSD. I've never seen one single bit of empiracle evidence to support your assertion that Redbook is as transparent as DSD.
Kind of backwards, again.
ALl of the paramters of RBCD have been proven transparent -- too meat the criteria for human detectability thresholds. How d o you get more transparent than transparent?
Unfortuntely, I don't have links. The papers are primarily AES papers that are not available except by way of aes.org. Or you can email me. The last reference is available online somewhere, you can search for it with google. I don't have the link at the moment. Or email for that one, too.
Which Bandwidth Is Necessary for Optimal SoundTransmission?
*. PLENGE, H. JAKUBOWSKI, AND P. SCHONE
JAES, 1980 March, Vol. 28, No. 3
Signal-To-Noise Ratio Requirement for Digital Transmission Systems
Spikofski, Gerhard
AES preprint 2196, Convention 77(1985)
Perceptual Discrimination between Musical Sounds with and without Very High Frequency Components
Toshiyuki Nishiguchi, Kimio Hamasaki, Masakazu Iwaki, and Akio Ando
NHK Labs
You misunderstand the situation- it's just a lack of any evidence at all. However, you are well versed about such things, and such evidence may very well exist. I merely have yet to see any.
I see. I thought I had provided references for you in other threads.
I do have a few questions: is there any good documentation of Redbook vs, say, 2" analog tape?
Redbook has specificaitons that suggest transparency, period, for playback. You realize, that depending on the noise reduction used, multritrack or stereo, etc., that analogue tape can introduce audible distortions. So it would be ideal to A--D--A the analoge source to compare the original to the sampled version. Such a test was done with 1/2" 15 IPS a few years ago in a studio. The results of this test are found on the official ABX website. But this was not a scientifcally valid test.
Are you assertion 16 bits is perfectly transparent to any source we could name? As you're aware, early CDs came with a notice printed in their jackets saying "Due to the high resolution of the CD medium, limitations of the analog source tape may be revealed." Newer remasters show this was absurd- many early CDs sounded awful compared to the original analog tape. I blame the master of the CD, not the Redbook spec itself, but I put it to you bluntly: is Redbook utterly transparent?
Earliest CD technology had problems: anti-alias filters, quantization noise, etc.. I prefer to focus on current possibilities, not ones from the past that are no longer an issue.
And is there any good scientific DBT comparing DSD to either a resampled PCM recording or an original analog tape?
I know of exactly zero scientificly valid perceptual research projects analyisng DSD audibility.
-Chris
