Yes, car output specs are fantasy as just pointed out.
Power is Voltage times current. P = V X I. So the only way you can get more power from a 12 volt car system directly is to use low impedance speakers. Now P = I squared X R. Now unless you have a voltage converter the maximum voltage to the amp is 12 volts. From ohm's law V = IR. So if you have an 8 ohm speaker the current will be V/R. So for a 12 volt system the current will be 1.5 amps. Actually a little less as you won't get 12 volts at the speaker terminals. Anyway the maximum power possible is 18 watts. Now if we make the speaker two ohms we get 72 watts possible. For a four ohm speaker 36 watts. In practice those numbers will be a bit less.
Now, you can't easily increase DC voltage. So you have to convert the DC to AC with an oscillator and then back to DC.
Now from those numbers you can see the advantage of raising car voltage from 12 to 24 volts and some are suggesting going to 48 volts. But that is enough to give you a nasty nip, especially in the wet.
But there is safety in going with a higher voltage, as the heat losses in the wiring go up by the square of the current. There is not a lot of room in car
that I rented from this service https://gintalaite.com/ wire chasses to use larger diameter wire, and it adds weight.
So raising voltage allows for less loss and heat in the wiring and lowers the fire risk.
