My intentions were to upgrade my present Sony DVD player to one that can do HD up conversion and supports either HD DVD or Blue Ray. I would like a clearer picture from normal 480 resolution DVDs and also set my self up for the future. Since there isn’t a conclusive standard out there, I don’t want to pay too much money at this stage, say $400.00. Nothing is as straight forward as you will see in the next paragraph, so I need some help here. My present system consists of:
Denon 3805 (non HDMI model, but supports Denon Link III)
Hitachi 51F510 (Does have HDMI input)
The problem lies with the Hitachi 51F510, which has a native resolution of 1080i. The Virtual HD that comes with this model converts non 1080i inputs into1080p, and then down converts it to either 1080i or 540p. That is what I have gathered from what I’ve read, unless someone wants to correct me on this. I certainly am not an expert in this matter.
Today, I was checking out the HD DVD Toshiba HD-A3 ($199) that supports 1080i, not 1080p. The more expensive HD-A30 model supports 1080p, as does the Blue Ray Sony players. Also, add to the mix I like to listen to audio too, so what will a Denon DVD player do for me with the Denon Link III. These are far more expensive, such as the 2930CI? What is this going to do for me?
Given these parameters that 540p is the best progressive resolution I can have and 1080p is not supported, which way should I go? I see my options being:
Buy a cheap HD up conversion and forget HD DVD or Blue Ray for now, costs $80
Go with the cheaper Toshiba $199 and have 1080i and a fully HD player, at a small cost
I don’t really have a comment on the Blue Ray or Denon option due to my in experience in this matter.
Any takers!!
