Broken Pin in Subwoofer
  • Thread starter Thread starter Terry22
Terry22
7
0
1
68
Help! broke the pin off in my sub-woofer, any ideas short of taking my sub apart, on how i might get this out? I tried to get it out with a dental pick, but i only manage to push it further in. It broke off in the right input, Can I just start using the left input ,as I only use a single cable. Or would this damage my sub? I can't afford to have it serviced by a Pro, at this time. Should I not use it till I can take it in? Any help would be greatly appreciated.
Earthquake Sub 120, 12" down firing sub.
You can use the left input, no problem.
Regards,
Wayne A. Pflughaupt
Regards,
Wayne A. Pflughaupt
Yes, no harm will come of using the left input.
Now for something I do not know, if the right input is also labeled the LFE input does that change anything as far as performance? I've always heard it doesn't make a difference but why are some manufacturers making a point of labeling only one input? It makes it look like you're supposed to either use both, or just the right one for LFE.
Thanks for the info. I'm on covd19 time so I did a little investigating , as I'm a new member, ihad a look around the site, there is a very good article on subs for beginners.On using both inputs,apparently it gives you some type of better or easier adjustment range after or before calibration. I will have to read it again. However the same sound can be produced with one. Go figure
Generally the advantage to using both inputs is a slight gain advantage, possibly useful if you have low output on your sub pre-out or only have L/R pre-outs and need the sub to sum the signal. Some subs have one input marked LFE and will bypass the sub's built in low pass filter automatically, but just dial it up to max otherwise (or to be sure). You might also see if you can access the connector better by removing the amp....or just use the other input as mentioned.
So just how hard would it be for me to remove the amp, and what would I be looking for , or what would it look like? Does anybody have a picture?
Not sure if this within my skill set.
If you're unsure of exactly what the amp on your sub looks like I would suggest that you don't even think about removing it. If you can't get the pin out with a pair of pliers and it works just fine using the other input I'd leave it at that.
So how did you break it off in there in the first place? :) Congrats on getting it out....
Here's the long answer I can only guess, i believe the cord was stepped on or got caught on something whilst I was moving it.My set up is as such that I had to remove my closet doors, turn a coffee table on end then build a small wall so i could hang my TV, the sub sits next to it,next to that is 1.7 Maggie. The reason I had to do this was I needed every extra inch of throw space for my Projector. On the shelf behind I have all my collectables which occasionally I have to get into. thus I have to move the sub. If anybody would like to see this let me know, I'll post some pics, might give others with tight spaces some ideas.
  • Like
Reactions: lovinthehd
Had it happen to me not long ago too, but I have a few tools and managed without much trouble. I do swap speakers around and my interconnects see more action than most. I'll admit to being a tad careless too. I know better now tho.
  • Like
I decided to create a loop and tack it down with tape, that way I'll here the tape pulling long before pressure gets to the connector. Fool me once,eh.
