Blu-ray player question
Rylan
I finally just made the big decision and purchased the Onkyo TX-RZ50.
For my Blu-ray player I plan to pick up the Sony-UBP-X7000-M. https://www.crutchfield.com/p_158X700M/Sony-UBP-X700-M.html
I also have an 85” QLED Samsung
I Believe I recall watching on one of audioholics YouTube videos that this Sony Blu-ray was a good player for movies. Does anyone recommend one that would be better that is around the same price point, or will this player do a great job? I plan to run 5.1.4 setup
As long as it plays the discs you want it to with the connectivity you need, I wouldn't worry about it. Blu-ray players if not good for movies are useless.
W
Wardog555
Why do people choose this receiver in particular?
Cheap? Or something else?
A particular panasonic model is labeled the best uhd blu-ray disk player.
William Lemmerhirt
William Lemmerhirt
I’ve got one. It works great. Responsive menus, easy setup, nice and simple. And not expensive either.
