Jedi2016
30GB will be enough to hold a high-definition film, yes. But it will have to be more compressed, and there will probably be noticable artifacts as a result.
You can fit a three and a half hour movie on a single DVD9. But if you spread the same movie over two discs, even though you're using the "same codec", the quality is vastly improved. LOTR demonstrated this quite clearly. I don't even have an HDTV yet, and my ancient 27" Sanyo displays a noticable difference when playing high-compression movies vs low-compression movies.
That comment about the "same codec" tells me you have no clue what you're talking about. Even the MP3 argument kills your statement. I happen to know quite a bit about how video compression works, thank you, since I work with it on a regular basis. Less compression = higher quality. There is no argument against this. A 50GB movie will look significantly better than the same movie compressed down to 30GB using the same codec.
So, let's ask another question... you keep asking us why we think Blu-Ray is better... so how about YOU tell US why you think HD-DVD is better? I can't wait to hear this.
