Umm, err...no...
Buckle-meister said:
Biwiring has no measured change on the quality of sound as opposed to using a single cable-run?
A bit of apples and oranges here...bi-wiring will result in slight measurable changes electrically...there really is no way to measure "quality" of sound...some folks perceive a difference, some don't...some say improvement; others say difference is simply difference....additionally, there are psychological factors involved and endless arguments surrounding many audio issues.
Biamping does have a measured change in the quality of sound
True bi-amping(or tri-amping) results in what is known as the "division of labor"...if the signal is separated into specific frequency bands prior to the final amplification stage, each amplifier has a smaller slice to deal with therefore should be able to handle things with greater efficiency...an amplifier with less output can be used for the high freqs as they require less power to be reproduced. The low-end requires more air to be moved and that requires more power...the issues involved are lessening various forms of distortions which may result as a single amplifier and it's power supply tries to deal with the entire waveform...dual-mono designs attempt to ameliorate L&R channel interactions in similar fashion.
Perhaps a better example are multi-channel units...say a piece is rated @100Wpc...now the question is: Is that with all channels driven? Is it rated 20Hk-20kHz or simply @1kHz? Most are not rated for full output across the entire spectrum simply because there is rarely the requirement to do so in real-world situations...if you tried to max out all channels simultaneously, most power supplies couldn't handle the load...a thermal cut-off would probably activate due to the heat generated and the 15amp AC fuse/breaker might even trip...there's math that can show this, but, off the top of me head, much more than 2+2=4 isn't my strong suit...suffice it to say individual amps, whether mono-blocks or dual-mono designs will fare better...of course your fuses may blow, but that's OK as you'll probably be bleeding from your ears and lying in a heap by that time.
Quality, again, isn't measureable HOWEVER, there should be a noticeable difference which some will find an improvement, yet others will not.
...with the least to best method being:
a)Using two power amps (because seporate boxes per channel are better than a combined box for all channels)
b)Using four mono blocks (because all frequencies are sent out of the preamp to the mono blocks)
c)Using a preamp with an electronic crossover circuit in it (thereby increasing headroom?) with, presumably, four mono blocks
a) OK OR two dual-mono amps could be used in any configuration...
b) OK Theoretically "better", perhaps measureably...qualitatively???
c) Actually, an electronic crossover is a separate outboard unit, so it's pre to Xover to conventional stereo amp, dual-monos or mono blocks...whatever you can afford, have room and the required AC circuits for...
jimHJJ(...good luck and good listening...)
