surround A for bi-amping?
After I purchased my 3805, I called Denon's tech-support line to ask this very question (amongst others). On the other end of the line, the very polite and knowledgeable Tony recommended that I bi-amp them (I had previously mentioned in a different thread that he told me to "bi-wire" them, but I was confused on my terminology
), as he himself had done on the 3805 he used at home. I am not a representative for Denon (thus I can only speak for myself), but based on what Tony the tech said, even if they don't recommend it, they don't seem to be discouraging it.
Here's my twist on the 3805 bi-amping procedure line of questions...
In my discussion with Tony about this, I stressed that I wanted to use the zone 2 outputs for speakers in my office, and play them in conjunction with the bi-amped fronts. He suggested a way for me to do this using my surround A outputs (since I'm not using any surround speakers), but I don't remember the exact procedure he suggested, and I am too worried about blowing something up by doing it wrong.
Does anyone know how I could safely do this? Could I just follow the same procedure as used for bi-amping using the zone 2 outputs?
Also, once I bi-amp them with the surround A outputs, is there any reason I could not use my microphone for the "auto speaker set-up" function, or would I have to do it manually?
Thanks all,
Stephen
