Already explained if you read all my posts in this thread:
Each channel does see a different load.
Yes, but its a voltage source, power across the load increases, but your woofer leg impedance will not change because you separate it from the tweeter. Again, for the last time, it's not so much the marginal increase in power, but the separation of clipping spectral components when driven hard (and a possible reduction in IM distortion due to the current loading on the output stage).
The bottom line is that passive (or vertical) bi-amping
does make a difference, but it should only be noticeable when you drive your speakers hard. It is clearly worthwhile if you have extra unused amp channels.
As you can see, now that Jerry has used Google Search, he realizes this also.
 http://forums.audioholics.com/forums/showpost.php?p=663628&postcount=8
cheers,
AJ
p.s. btw Cobra, the "clock radio" thing was
this. Classic Jerry
