Beginner Audio System
templemaners
I understand that I'm on a tight budget.
However my current plan is:
Step 1. Get a pair of speakers(Pioneer BS21 $50 or Dayton B625 $40) and an amp(Lepai LP 2020A+ $24 or "suggestions awaiting")
Step 2. Get a DAC(~$120)
Step 3. Get a Subwoofer if required.
Step 2 and Step 3 will be taken later on. The total budget for everything is around ~$250. I will be able to extend the budget for DAC and sub later on.
What about this amp Amazon.com: AudioSource AMP-100 Stereo Power Amplifier: Electronics ?
Do not spend 2-3x as much on a DAC as you would speakers, especially if you keep going on about how limited your budget is.
BEST
SPEAKERS
YOU
CAN
AFFORD
^^^ Repeat that until it sinks in. The speakers are miles and miles more important than a DAC, and if you want good bass, you're going to need a subwoofer at some point.
GranteedEV
GranteedEV
A dac?
Really?
Why do you think you even need a $120 DAC?
You can get a perfectly adequate external sound card for a lot less than that:
http://www.turtlebeach.com/products/sound-cards/audio-advantage-micro-ii.aspx
99% of the sound quality is going to come from the speakers in the room unless your electronics are audibly noisy. Your speakers should normally represent 70 to 90% of the system cost.
As far as a subwoofer goes, I've found that content below 80hz is overated unless it's exaggerated. You can probably get away with no subwoofer until your overall budget can actually accomodate one.
slipperybidness
slipperybidness
Both speakers, have limitations in the loudness department. Also,
raising the volume on a low power amp, will not help.
Compromise tends to be the name of the game, with a real tight
budget. For the type of music, and the bass that you desire - you
will need a subwoofer in your system.
Compromise is the name of the game, with almost any budget.
+1. Speakers first, DAC last or even a receiver with built in DAC.
markw
Sometimes, when a thread goes on this long and...
...so many good options and explanations are offered, and OP simply refuses to accept them but persists with seeking validation of their original, flawed plan, I start to wonder if Ashton Kutcher is on the other end of the internet. :confused:
ahblaza
ahblaza
Think speakers for now, SPEAKERS, I don't recommend the Pioneer BS21's, I have these Newegg.com - Pioneer SP-BS41-LR 2CH Bookshelf Loudspeakers Pair
They are an excellent speaker, I picked them up on Newegg with promo code last week for $90 the pair. I also highly recommend these;
Newegg.com - Pioneer SP-FS51-LR Floorstanding Speakers Pair
on sale right now for $130. You really can't go wrong with either of those speakers, and as Mark said look for a stereo receiver like this.
Onkyo TX-8255 50 watts 2 channel Stereo Receiver | Accessories4less
Hope this helps.
Cheers Jeff
zieglj01
zieglj01
I understand. So I need to get a more powerful amp and a subwoofer that can be added on later if required. Any suggestions on the Amp? And DAC?
I would hands down, take the Pioneer speaker over the Dayton one.
However, I would really take the BS22 over the BS21 - the BS22 has
a deeper and more defined bass, better midrange and more extended
highs. Your choice.
Also look at the RBH AC51 - good deal
http://www.ebay.com/itm/271055040118?ssPageName=STRK:MEWAX:VRI&_trksid=p3984.m1438.l2661
http://www.rbhsound.com/ac51.php
I also reccomend the Sherwood receiver, that markw reccomended.
Sherwood RX-4105 Stereo Receiver 252-125
As far as a DAC - no reccomendations, not really needed.
ahblaza
ahblaza
Knowledge is knowing a tomato is a fruit; Wisdom is knowing not to put it in a fruit salad. :D
You said it all brother.;)
markw
True, but some additional thoughts.
(I'm posting this for any lurkers who might actually be taking the good advice offered here to heart)
I know jiminy about sound cards so I'll just show my intelligence by saying nothing.
True, but you need adequate power to get the best out of any speaker. I got to play with those Pioneers 41's at Best Buy. They are great: clean, detailed and everything I would want for a satellite speaker, but they are only 4" drivers and are quite inefficient.
Keep in mind Hoffman's Iron Law of speaker design: Small size, good efficiency. Pick two, any two.
True, if the mains can go down to a reasonably low enough frequency to be musically satisfying. Remember, the Pioneers are only 4" drivers.
And, I have those Dayton 652's. Flat and uninvolving. They are sitting in my basement, unused. Five or six of 'em with a subwoofer would be a good starter HT set but, for music, well, I'd take the little Pioneers with power any day. ...but, while they will be satisfying in a musicsl, well balanced way, you'll really want a subwoofer to fill in the bottom octaves pretty quickly.
GranteedEV
GranteedEV
Agreed. That's why a 3-way would make more sense if OP were sitting far away. For some reason I assumed OP was going for a nearfield setup. In my nearfield setup, which uses the NLA beryllium woofer version of these:
EMP Tek E41 Bookshelf Speaker
I feed them about 20w to 30w from the aformentioned SMSL SA-50 amp. it was a lot of output for a small room in the nearfield. I also feel no need for a subwoofer despite the 4" woofer. They extend down low enough with enough output that i've only once heard them strain, at levels well beyond my comfort zone. I can't comment on the pioneers as obviously they're in a lesser price class.
ahblaza
ahblaza
Mark, the Pioneer BS41's have a 5.25 driver, the FS51's have three 5.25 drivers with a stated 45Hz-20KHz FR, I think you were listening to the BS21's, they do need some extra power to sound their best though :D
I
itspb
I'm honestly surprised that with the price difference between that audiosource power amp and the sherwood receiver, you just blew the sherwood off without a thought.
Putting money into a DAC with that system is like putting $3,000 wheels and 20 inch tires on a Yugo.
But, it seems you know what you want to do. Good luck.
I didn't disregard the Sherwood. I just wanted to know if there is a substantial difference between the quality of both the amps.
Speakers and Amp more important than DAC, point understood.
If I knew what I was doing, I wouldn't have come here to ask you guys for help.
Now this is just flaming. Agreed that options are being offered, but I still need to confirm that they are good enough or not. Imagine yourself in my shoes where I have to spend every penny carefully. Its not easy bro. At the end of the day I don't want to blame you guys if I don't like the system. I hope you understand.
Now we are talking. So Daytons are out. Are you talking about Pioneer BS21 or 41?
BEST
SPEAKERS
YOU
CAN
AFFORD
Understood, gonna add subwoofer later on, that is, if I need one.
A dac?
Really?
USB Sound Card | Audio Advantage Micro II | Turtle Beach
Sound Card or DAC, which ever is more feasible. Well once i get the speakers and amp, i will decide on subwoofer.
Thats the plan.
Hope this helps.
Cheers Jeff
Is the $90 sale still on?? The newegg page doesn't show any promo code. :\ As much as I would like to get that floor standing speaker, i don't have enough space to incorporate it. I'm in a college dorm.
What is the main difference between a receiver and an amp?
highs. Your choice.
RBH MODEL AC51SILVER 2-WAY BOOKSHIP SPEAKER (PAIR). | eBay
How do the RBH AC51 stand against BS22 and BS41? Is there a huge difference in the quality of the sound?
RBH AC-51 Bookshelf Speaker
The Sherwood or Onkyo?
On a different note, are these amps really big? I need to figure out where I will place them.
I
itspb
Just to reiterate, my room is a rectangle 10X18. It will be a near field setup. Atleast thats what i think. Just to give you guys an idea, here is floor plan. My room is 403A
markw
Good point. I must have heard the 21's when they were on sale for $80. In any case, I don't think tht extra 1 1/4" will significantly increase the low end. Remember, that frequency range doesn't specify the deviation, just the extremes.
zieglj01
zieglj01
My choice is Sherwood - it is good for the price, and has power
I am not a big fan of the Onkyo line
Sherwood size
17-3/8" W x 4-7/8" H x 14" D.
The Onkyo is about the same size.
markw
No, it's not flaming. It's frustration.
There's nothing more aggravating to us than to throw out oodles of good advice only to have it ignored.
Yes, you did. I chose my words pretty carefully. You didn't even bother to read my post enough to realize I suggested a receiver and you threw up a power amp.
A more fitting question would have been to ask the difference between the two.
I'll leave that for others if they choose.
zieglj01
zieglj01
For your room, something like the Pioneer's will work nearfield.
The Pioneer's sound better in a room - and will play louder, than
they would in a big open area, like Best Buy.
slipperybidness
slipperybidness
Just be sure they have room to breath behind them. The pioneers are rear ported.
GranteedEV
GranteedEV
Okay, now i'm pretty sure my suggestions are all you need.
1X This - $25 (Don't get this first though. Your laptop's analog outputs may be better than you think)
1X This - $4
1X This - $75
1X These - $125
and some of this
I
itspb
Sherwood size
Okay. 17", thats bigger than my laptop.
If you have frustration, breathe hard and take it out on a stress ball.
I was under the impression that receiver and the amp did the same job. And yeah, that was stupid of me. So what is the difference between the two?
