SopRage
SopRage
Yo.
Come tax season this year, I should be getting a pretty hefty refund. Naturally, I want to use some of it to upgrade my setup, and I think I'd like to start with improving my bass.
Right now I've got a HSU VTF-2 MK-3 in my front left corner. I only really have one corner of my room I can use for a subwoofer - I can't use the front right corner since it's shared with a door, the back right corner is some 17 feet behind the couch, and the back left corner is 25+ feet away. In addition, the basement isn't really separate from the rest of the house so I'm basically pressurizing my house.
I can put together some $2000 give or take a bit, and have been looking at the following choices:
1)SVS PB13-Ultra
2)2 HSU ULS-15's (stacked)
3)1 HSU ULS-15 plus an SVS AS-EQ1
4)2 Rythmik F12 SE's or F15's (stacked)
5)1 Rythmik F12 SE or F15 plus an SVS AS-EQ1
I'm about 80% gaming, 10% movies, and 10% music.
Any thoughts?
shadyJ
Speaker of the House
Staff member
The ULS subs will be the most expensive, but will be the most powerful of all those solutions. Some other options to check out are a couple Epik Dragons, or maybe a couple Elemental Designs A7s-450s, or a Elemental designs A7s-650. You might also take a look at getting a Seaton Submersive. But two stacked ULS-15s would be a lot of power with a relatively small footprint.
djreef
djreef
Yea, my vote would be for the ULS 15's if you could swing it. You could always add the SVS-Audyssey black box later if you feel the need.
DJ
agarwalro
agarwalro
Unless you are having some serious room acoustics generated issues (and since music makes only 10% of your system use), IMO, the EQ1 is a waste of moeny.
SopRage
SopRage
I'm surprised it was this clear-cut! Well, guess I'll start saving for the ULS-15s. If I can't scrounge together the cash, I'll splurge on the PB13, I think.
