Keep in mind...
When comparing Signal to Noise and Dynamic Range measurements done by the Audio Precision...
For SNR the signal level is arbitrary, is usually taken to be the
nominal program level. SNR is actually
two measurements:
- 1st for the signal level
- 2nd the noise floor level with the signal turned OFF
Then these two measurements are expressed as a ratio, typically in dBs.
However...
Often like most noise measurements done with the AP, the SNR results are bandpass limited using
high and low pass filters, or a weighting filter. Whatever specs are published, the filters used should be disclosed, this is often not shown for AD or DAC SNR specs.
Dynamic Range is another spec, and is the ratio of the highest signal a device can pass to the device’s noise floor, usually specified @ 1% distortion. Signal-to-Noise Ratio and Dynamic Range specs are basically the
same measurement, except that the signal in SNR is arbitrary ( but should be disclosed),and the signal in Dynamic Range is at the maximum. The majority of these specs follow the AES standard and/or the IEC.
Bottom line..
Here the highest spec number is not always the best...
When comparing units, be sure to note what filters are used and @ what level...
Just my $0.02... ,
