You weren't wrong about them being close, in fact they have exactly the same gain, 26.4 dB. The KAV needs a little less input voltage only because it is rated only 200 W, 8 Ohm, vs the FPB-200's 250 W into 8 Ohm. With 1.92 V from the preamp, either amp will output about 200 W into 8 Ohm.
Bridging a good power amp rated for 4 Ohm is okay for 8 ohm nominal speakers. If you do that with the Marantz MM7055 (assuming that's what you referred to), you risk damaging it and void the warranty.
You are right, if you use XLR, you will get higher distortions though as Gene mentioned, the level would still be below the threshold of audibility, probably about the same as the AV7705 if I remember right. The CX-A5100 did not have that issue, but I doubt you can find one.
If I am in the situation you are in, and cannot wait, then I would just get the X3600H or X4500H and keep the savings in the bank while waiting things to shake out.
None at the moment, unfortunately. In fact, even for 6 K, I can't think of any. At the price point of $5 to 7K there are a couple that comes with Dirac Live but I am confident in their reliability and may not be bug free yet at the moment. Even if those are not concerns, I would only consider them if I were much richer.
I think I am going to stay with my cheap X4400H (replaced my AV8801) for a couple more years. By the way, today I spent some time listening to my HD tracks using the AV8801, and no matter how hard to try, I just don't think it sound any better/different than the X4400H (used as prepro).
It would be really easy to justify the Yamaha if you think it beats the 7706, or perhaps an AVP as you mentioned. I like my SACDs and 2.1 channel listening, but it may just be that I have been running a fools errand with the Krells (I suspected as much when I went to hear a friend of mine's M. Levinson setup with Revel Ultima Gems but that rig made mine look affordable lol- and those were 1999 dollars), so I am getting a little excited about improving the fidelity of my "audio mediation sessions."
Going by the measurements the CX-A5100 should beat the 7705 (and the 06 assuming the audio performance would be the same). The CX-A5200 too, if you use RCAs.
