AVP 10 is in Route to Dealer.
My dealer has informed me that my Marantz AVP 10 is in route to his store in Minneapolis.
I have ordered a 19" rack mount for it from B & H photo. I guess if the AVP is good enough for Gene it is good enough for me.
So I will report further when is installed and set up.
I have found a way to keep the AVP 7706 quiet. This buzz issue is very much heat related. If you keep the case stone cold with two fans positioned just right, and on full blast, the unit stays quiet, and there is not a sound audible in any listening position with no signal into the unit.
The mechanical chase temp is 73 almost constantly, as this house has very good temperature control. My current cooling keeps the case 77 to 78 F. Without the fans the case temperature rises to 95 to 98 F.
I have to think that this issue is likely caused by a bad electrolytic cap. The video below I think sheds some light on the issue and some premature failures other members have endured.
My 7706 is not ethically saleable, so I will move it to the family room system and see what happens.
Neither myself or the dealer think it worthwhile sending it for service as a service center won't likely have the patience to reproduce the fault.
