AV Stand: Doors or no doors?
BMXTRIX
BMXTRIX
So you have holes in the base of the stand and since the stand actually sits a few inches off the ground you can run the wires down through the bottom and out to reach the wall (instead of cut-outs in the back panel)? That's something they could easily do - basically they will cut any number of holes of any size anywhere you want them.
Yes, and the nice part is that this is a good source to feed cool air into the rack since it is, most definitely, the lowest, and coolest point of air entry.
