Audioengine A5+ Bamboo vs Black
Z
ZSamuels28
Hi Audiophiles,
Is there a sound difference between the A5+ Bamboo and A5+ Black? I am looking to purchase them and wanted to know if the Bamboo makes any difference in SQ. If so is it beneficial?
Thanks
Irvrobinson
Irvrobinson
I can't believe there's any difference in sound.
Irvrobinson
Irvrobinson
According to another forum, Bamboo is more resonant and needs tweaking to sound the same as mdf.
I've heard both, but not side-by-side, though I don't remember hearing anything amiss with either. I ordered them in white just for aesthetic preference. If you're really concerned I'd call Audioengines and ask them about it.
Z
ZSamuels28
I just talked to Audioengine and the guy said he's heard them both and can't notice a difference. They've taken all steps to make sure they sound the same. He said that the majority of people said they like the bamboo better, but he said that could just be a placebo effect because they cost more. He said the reason MDF is used is because it's cheaper and standard. The bamboo is hard and not porous so I think it should sound the same.
I wouldn't expect it to be so different that it would really matter. I definitely prefer the look of the bamboo model.
