Audio Research amps
DrMorbius
DrMorbius
Seems both channels evenly matched at 8 ohms, which is my preferred setting.
m. zillch
m. zillch
Yes the blue and red almost perfectly overlap. That's what happens when people connect resistors to their amp rather than actual speakers which have a widely varying impedance per frequency, even if they (the speakers) may simplistically describe themselves as "8 ohm". They means that's their average/nominal impedance.
As I added in my edit it is the "simulated speaker load", the "gray" (looks black to me) curve, which I think would be audible with the right content.
m. zillch
m. zillch
ALL of these various colors were made with the amp output set to 8 ohm. See my bold text of their statement, below:
""Fig.1 Audio Research I/50, 8 ohm output, frequency response at 2.83V into: simulated loudspeaker load (gray), 8 ohms (left channel blue, right red), 4 ohms (left cyan, right magenta), and 2 ohms (green) (2dB/vertical div.). "
ski2xblack
ski2xblack
That blue is the other channel, but that's into a purely resistant load. That graph illustrates how higher output impedance results in linear distortion into a reactive load. Keep in mind that distortion can be broken down into linear distortion (freq response aberrations, which can be quite audible; that sort of nonlinearity can intentionally added via eq for that matter) and nonlinear distortion (harmonic distortion, which with the ARC amp should be negligible and inaudible).
