ASR review of Pioneer VSX-LX505 (Onkyo RZ50)
dlaloum
Isn't the puck mic considered bad for calibration vs the tower one?
Sent from my SM-S916U using Tapatalk
Not really, different housings, same mic cap capsules...
They are "batch calibrated" - that means they are calibrated to a production average. 80%+ will be on the mark, 95% will be close enough for it not to make a difference in actual use, and about 5% might be substantialy off the mark.
Individually calibrated mikes are better only about 1/20 times - but you get the confidence of knowing that the measurements are correct
asere
If you use the provided puck. How long does it take to run Dirac Live for 5.2.4 setup?
ban25
ban25
Perhaps 20 minutes assuming 5 or 6 measurement points. 30 minutes if you do 9+.
