D dlaloum Audioholic Chief Nov 18, 2021 908 0 16 61 Jul 11, 2023 #161 asere said: Isn't the puck mic considered bad for calibration vs the tower one? Sent from my SM-S916U using Tapatalk Click to expand... Not really, different housings, same mic cap capsules... They are "batch calibrated" - that means they are calibrated to a production average. 80%+ will be on the mark, 95% will be close enough for it not to make a difference in actual use, and about 5% might be substantialy off the mark. Individually calibrated mikes are better only about 1/20 times - but you get the confidence of knowing that the measurements are correct Reactions: asere
A asere Audioholic Feb 3, 2012 113 0 18 Jul 11, 2023 #162 If you use the provided puck. How long does it take to run Dirac Live for 5.2.4 setup? Sent from my SM-S916U using Tapatalk
ban25 Full Audioholic Nov 8, 2022 269 0 16 Jul 11, 2023 #163 asere said: If you use the provided puck. How long does it take to run Dirac Live for 5.2.4 setup? Sent from my SM-S916U using Tapatalk Click to expand... Perhaps 20 minutes assuming 5 or 6 measurement points. 30 minutes if you do 9+. Reactions: asere
