Any iPod experts Here?
  • Thread starter Thread starter Squishman
Squishman
Squishman
2,570
0
38
66
Ipod touch 6th gen will not connect to iTunes, let alone sync. It just doesn't show up. Windows 11 desktop with iTunes 10, which is very old. I hate the look and functions of anything newer. This version synced fine before. Tried restarting the computer and restoring the iPod.
I have another 6th gen ipod touch. Both are 32g with a different set of tunage. LP's only. The way I tell them apart is one is white, one is black.
So with "prevent from syncing automatically" checked, I tried the other ipod. I cannot allow it to sync with the desktop as it belongs to my laptop's iTunes. Anyways, that iPod is not recognized on the desktop computer either. I just checked under "devices and drives" and the computer sees the ipod, but iTunes does not.
Anything else I can try?
I even bought a new usb cable in case that was the issue.
No. It worked just a handful of weeks ago just fine. I don't sync unless I add something or make a change to my iTunes.
My wife has, and likes those old fashioned devices. Apple have not supported that device for years. My wife still has a docking station for hers, which unfortunately still works. However it stopped being able to be synched to our AVP in our great room years ago. When my wife puts that contraption in the Altec device in the kitchen, I run upstairs fast.
Your unit is a recycle job.
  • Funny
Reactions: Squishman
It may be an issue with the USB port on the iPod side. Earlier versions of USB (pre-C) ports had a finite number of connections they should support, which aren't larger numbers.
See here: https://en.wikipedia.org/wiki/USB_hardware
It's up to you whether the repair cost is worth it. If you're curious, contact several third-party electronics repair shops, and don't be shocked by the price, which I expect to be around $200.
You could also do it yourself - see a few resources below, but then you need experience with micro soldering and specialized repair equipment.
These guys say they will do it for only $99:
But then again, you could buy a brand new 32 GB smartphone for only $95:
Alternatively, if you like to stick with Apple devices - an iPhone SE (1st gen), which is a bit newer than the iPod touch 6th gen - costs even cheaper at $79 or less on eBay with 4x the capacity - 128gb or $74 for 64gb version in Excellent/Mint condition:
Also iPhone 6 is basically the same device as iPod Touch 6th get, with later cellular parts disabled and used devices in great condition with 64 GB storage for even cheaper under $40 :
My wife's has not synced with our Marantz AVP port for a long time, and the cable is fine.
This is bizarre. I fired up my Acer laptop for the first time in months. I opened iTunes and made sure "do not automatically sync" was checked. Remember, I had reset the black iPod to factory. A window in iTunes opened that said "welcome to your new iPod". So the iPod works! The desktop itunes is v. 10. The laptop is v. 12. Both super old. I will try uninstalling itunes on the desktop and re-install it with v 12. If I still have the exe file and I imagine I do.
If that fails, I like @BoredSysAdmin 's idea of an old iphone. But I do not exactly know how to differentiate both folders on one iPod or iTunes for that matter. I'll cross that bridge if I need to. btw, my black one is 64g, the white one for LP's is 32g.
I know it's not very helpful to you, but I think Apple made iTunes on Windows particularly painful/slow on purpose and I can't stand it, but on same period Apple devices, for "some reason" iTunes works perfectly fine, and fast.
Apple killed off iTunes for Mac and incorporated the iTunes store in others apps. The same is happening slowly over on Windows PCs. Look for the Apple Devices app.
I like drag and drop players. But car radios will control an iPod. My Journey Crossroad has upgraded sound. So it's pretty convenient to have your whole digital library with you sometimes. The other option is to bring a stack of CD's! Nope. Wouldn't be prudent. Not gonna do it.
Hey, V. 12 works! It recognized my iPod right away! My iTunes library was all there. Syncing all the data now.
  • Like
Reactions: Trebdp83
Oh. I just noticed that v. 12 is not old. I thought it was. Still, I will not update it.
Over 50 minutes so far and it's only half done. 42 gb of data on this iTunes. I am recording my favorite podcast to listen to tomorrow though (no download button that I can find, so I record it everyday). RAM is 16 gb.
I have a drag and drop mp3 player for podcasts btw.
I use a 64 gb iPod still no support for it on apple lately. That being said somehow weeks back it somehow lost all content had to reinstall every single song . There’s like 20 days of music on there had to sync it all back on there took about all afternoon to do . No idea why it did that but a reset seemed to fix it . My laptop did not want to recognize my iPod to sync it up to my library . No idea what I did to get it to allow sync again . Man what a pain .
  • Like
As someone who is not really portable music savvy, why would I store music when a streaming service seems like an endless version of the same thing, minus the storing part? I have slowly and stubbornly gotten into streaming, but for some reason it has held me back from wanting to store music other than vinyl or CD and some FLAC files on my PC, and even then, I haven't added anything to them in ages. Just curious. I just plug my phone directly into my active LSR305s at work and let spotify or Pandora run the show.
In spite of what quibbles can be made with reference to SQ differences, I have since forgotten to notice the difference. In my bedroom it's just Spotify on WiFi to the WiiM amp and even that sounds surprisingly good. I would otherwise have to keep an enormous playlist to keep from looping the same catalog all of the time. I used to collect music when there was no connected database of it available and the radio stations being so limited with their selections.
