Okay so before I was planning on a separate 2.1 and 5.1 setup in the same room, using a cheaper 5.1 system, and the nice 2.1 music setup. They would be sharing the same sub. However.... I started thinking, why not integrate the LSI15's into the 5.1, and just buy some decent rears and a center that would not be overpowered by my sub (polk dsw pro 500 12") and my towers. Now is it crucial to get the same amount of power to every speaker? The towers will get 200 at the very least from a dedicated amp, should I buy a 5.1 receiver and give the remaining center and 2 rears 100 watts?
Also, is 7.1 worth it over 5.1?
Is it even possible to run my setup with my towers off a dedicated amp, and the others off the receiver? Will that sound awkward? Should I buy a 7.1 and bi wire the towers and go 5.1? There are tons of options... what do you guys think is the best option, because I really don't want to spend a whole ton on the other speakers. Thanks again!
