Well, I'm hoping I'm not a pain in the rear, but it seems you all tolerated my questions and postings.
To your question/request regarding feedback: your posts, and many others, have been technical/understanding enough for me to understand where you're getting the numbers. I'm a little lost on the Amps/Current deal, but I have the gist (?). I guess the only thing I'm lost on regarding current is how do you know if the numbers you got from the amp will work for the speakers you're driving and when is it good to have enough headroom?
Well, let me give another real world scenario with some related info as I mentioned I would post earlier. So my CFO/Lovely wife approved of the borrowed sum of $500-$800 (I might even be able to go out still to get GTA IV
). So I've been pretty much set on buying either the Emotiva XPA-5 or the LPA-1. Listening to yours and other posters' suggestions, I learned that headroom would be good for power output (obviously) and the fact that a larger amp would probably last longer over the long run if I'm running all channels at higher volumes constantly, or playing a lot of opera/classical/orchestra (which is not far from my taste).
I almost bought the XPA-5; in fact, just 5 minutes ago I clicked out of the browser thinking to myself that I should be sure to think about it one last time. So, I thought to myself, "What's the difference really and would more wpc be worth the extra $300?" Well, looking at the numbers:
(From these sites:
http://www.emotiva.com/xpa5.html and
http://www.emotiva.com/lpa1.html)
LPA-1 offers 5 channels - 4 Ohm @ 225wpc and 2 channels @ 95wpc
XPA-5 offers 5 channels - 4 Ohm @ 350wpc
(If all calculations are correct...)
LPA-1 offers 7.5a per 5 channels and 4.87a per 2 channels with THD 0.04%
XPA-5 offers 9.35a per 5 channels with THD 0.007%
(Looking at the Dynaudio Audience 72 specs:
http://www.dynaudiousa.com/products/audience/72/aud72spec.htm)
((210w IEC long-term Power Handling) / 7.8 ohms) ^ 0.5 = 5.18a
((210w IEC long-term Power Handling) / 3.1 ohms) ^ 0.5 = 8.2a
So these calculations result in a fluctuating current of 5.18a to 8.2a, of which I need to use to figure out how/what will drive the speakers sufficiently to its max wattage handling? So if I want an amp to drive these speakers at 8.2a, it seems the XPA-5 would more than enough? Am I missing something else in the number game or do I have the idea?
I know looking at the THD alone that the XPA-5 would make an orchestra's cello sound more like a cello; therefore, theoretically, making it a better choice on just that number, much less the wattage, if I was only going for clarity & quality. But the problem I have now is worrying if I'll need more current to power my speakers (?), much less be able to hold stable at a low 3.1 Ohms. I contacted Emotiva, but they have not replied to my inquiry, though it might need to take a little while before they get to it.
I'm a little eager to purchase since after Monday, hopefully, my damn "bad" carpet will be replaced and I'll be able to put my life back in order. I've been eating out for the past several days since I've moved almost every piece of furniture into my kitchen and bathrooms. Essentially, I only have 2 electronics hooked up: my laptop and wireless router. I decided the other day to calm down and not bother with hooking up my Yamaha RX-V663 this weekend just to play with my "new to me" Dynaudio Audience 72s. I think it's better to be safe and wait for the amp I guess...
