Ok i feeling a little overwhelmed right now and need some advice. I am just a beginner in the audio world and dont have very much knowledge.
Usage: room not built yet but max 16ft x16ft with 16ft ceiling and will be a man cave home theater. 70% gaming , 20% movies , 10% music
Owned: yamaha rxv685 avr , 4x klipsch rp600m's , klipsch rp450c , rythmik lv12f
I have a plan but dont know if its a good one. I have a Rythmik LV12F 12 inch sub thats sounds great but im wanting more bass. I'm on a somewhat fixed budget so im trying to get the best results for the price.
1.Is it a good mix to add a full marty box with a dayton ultimax 18 inch sub +crown 1502 amp or something else for bass at the same under $1000 ?
2.Is there a way to use the rythmik lv12f closer to my position to act as a mid bass module and the ultimax farther as low end and is this a good idea ?
3.Should i instead just build 2x full marty's with 15 inch ultimax's?
3.Does anyone have any better suggestions ?
Thank you all
