cugel
Hi, first post for me and glad to be here. Like a lot of noobs I am looking for advice on system upgrades etc. Currently I find my listening room to be ~10x15x8. So pretty small. I like to listen pretty loud; far above normal conversation but not obscene by any means. I don't get complaints from the wife if she is on the other side of the house. First and foremost I am a music lover and can't live without it. I don't know if that makes me an audiophile... Mostly pop, rock, vocals, you name it. My setup is pretty old and I picked it up piecemeal by scouring classified ads etc
Bryston 4b (pretty old but a brute; pre-toroidial transformers IIRC)
Perreaux pre-amp
Audio Alchemy CD Transport
PS Audio Digital Link II DAC
Rega RP1 turntable (most recent purchase; considering the upgrade kit)
Def Tech BP10s
I am underwhelmed by my system. Vocals on the BP10s can be sweet but highs and mids can get really harsh and fatiguing IMHO. Bass is lacking what I need. What would you do? Is it the speakers? Now I have been mainly looking at speakers online (under 2 grand) and do not know if my small room would benefit from monitors: LS50s, Aperion, PSB, Paradigms. Will these require a subwoofer for real low end? Also mid-size towers seem like a possibility as well from similar makers including Monitor Audio and Salk. OR am I polishing a turd here? Is it time to upgrade everything? Is any of this stuff "a keeper"? Could I spend about the same money on modern gear and have more time and pleasure listening (my end goal)?
Thanks for your input and don't worry about hurting my feelings but I am a noob...
cheers to all
zieglj01
zieglj01
The main issue is the speakers
I would aim for bookshelf speakers and a subwoofer
markw
The gear is good, very good. I'd stay with it.
I'd start looking at speakers but, in the meantime, a GOOD subwoofer will be a boon to any full range speakers you either have or will wind up with.
Ponder the Hsu and SVS websites and see what looks interestingto you.
cugel
Thanks
I have been looking at the SVS site and they seem like they put out products that are well liked and at reasonable prices. I will look at Hsu as well
cheers
For that size of room the LS50 and a good sub will work well.
shadyJ
Speaker of the House
Staff member
You can't go wrong with some KEF LS50s, and a good pair of subwoofers. Hsu and SVS are great options, and Rythmik should be considered as well.
cugel
I was afraid someone would say "pair of subwoofers"...
thanks for all of your input
still more research to do and beans to count
shadyJ
Staff member
Four? At LEAST four. I was thinking four subwoofers per channel. I wouldn't even start with anything less than that. No worthwhile sound system can have less than four subwoofers per channel!
cugel
is it ok if my wife contacts you to verify this?
