Hi,
If you were having issues with crossover (being so high that is localized) then maybe. If you were trying to create a center channel that had the lowest crossover, this would do it. This essentially is making a full range speaker on your center channel, but the sub connected to it would need to be in the center too, as it would cover a range that would likely localize (if it didn't then it adds nothing since the subs on LFE with crossover would handle it). If you had an AVR that could do different crossovers for each channel you could configure your center to be more full range and keep some lower crossover on it. But ultimately, it begs, why? The problem is, if the center speaker doesn't dig deep enough, and the sub added doesn't ascend high enough, you end up with a weird gap still. Plus you'd have to really balance the two (using high level input and manual gain on the sub) so that one end of the frequency spectrum isn't overpowering and just sounds extra boomy.
Very best,
