You're even willing to compare your two speaker models, but are you against trying the idea of putting those Energy's in another room, in order to be more sure if your lack of complete satisfaction stems whatsoever from the speaker itself?
I was quite satisfied with the Energys while they were on stands, prior to the cabinet installation, so I'm hesitant to blame them. What I'd
really like to have is a pair of Paradigm Studio 20's. But, with a wife whose agreement to any audio investment is more from tolerance, than enthusiastic approval, I'd have better luck convincing her to purchase in-walls than another pair of free-standers. Then, she'd see a "practical" improvement from the change. Sigh...
If willing to build something, I wonder if placing them on a small acoustical treatment (custom made of course, to be unobtrusive) would help to absorb some midrange (and hopefully lower midrange) affecting the boundary interaction with the cabinet. See, I wonder how much resonance is still created even if that speaker was not at all touching the cabinet, but say in free space just a few millimeters away. I'm just wondering out loud.
I'm not sure I understand what you mean. Are you saying that if I were to wall mount them, but they are still in close proximity to the cabinet, you think there might still be issues with resonance? I had been mulling over a possible wall mount bracket design over the weekend. I did some searching for a commercial design, but I didn't see anything with a long arm to get some distance from the wall behind the speaker. So, what I'm thinking is to construct a wooden bracket which incorporates a socket. I'd make another socket that would be bolted to the back of the speaker. Into each socket, I'd insert a wooden arm of whatever length I needed. In fact, I thought I'd make arms of 2 lengths - one short (WAF), for everyday ambient listening. I'd make another longer arm, 12" - 16" to get some distance from the wall, for critical listening. If the arm was 16" long, it would put the
back of the speaker at the front edge of the cabinet shelf. I would mount the wall bracket so that the speaker would be an inch or so above the shelf. Of course, I'll have to do some experimentation on the bracket design to ensure it'll be strong enough. These speakers weigh 28 lbs each!
However, should I encounter resistance to that idea, or should anyone more knowledgeable than myself deem this wall mount idea to be less effective than de-coupling pads, than pads it is. Pads may take care of or at least reduce resonance, but I'd still have the close proximity to the wall behind.
That's where some electronic correction might be necessary, such as:
I agree that the Behringer products, perhaps namely the DCX, could be a great boon. One of the first people I'd probably try to bother in helping me implement one is our respected moderator, annunaki.
Have you been reading the "Custom In-wall Sub" thread in the DIY section...?
My crystal ball tells me that dual stereo hidden in-wall subs are in your future.
Thanks, once again!
