mys_iii said:
placing them facing the length of the room has greatly improved the soundstage. I never realized just how much speaker placement AND room acoustics affect sound coming out of speakers!
I'm glad to hear that suggestion paid off for you. It's always amazing to me how big an effect room acoustics can have compared to many of the more commonly tried but less effective tweaks that fill the audiophile market place. Unfortunately, I often find that the best sounding arrangement of speakers can be impractical or impossible to live with in the real world. So compromise is the game.
mys_iii said:
Here's a ? for you 'bass' setup gurus. I have tried different positions for my speakers ( closer to the walls and further away from the walls, etc. ) and now have the following issue. I sit about 7' from the speakers and bass is greatly improved. The issue now though seems that if I go back to about 10', the bass is very good. If I sit at 7', it's just okay. I can't really sit 10' back as that would put me in the middle of the living room. Is there a way to control this at all via the positioning of the speakers? The bass seems to radiate upwards so if I go 10' back and stand up, I really hear and feel it.
What you are describing sounds very much like the common problem known as standing bass waves. In bass frequencies (below 200 Hz) reflections from the walls, floors and ceilings in many rooms cause additive peaks and subtractive cancelations to occur at various frequencies and different locations within the room. If you have a CD with various single-tone bass signals recorded on it, play a single tone, such as 60 or 80 Hz. Walk around the room and listen for the spots where you can and cannot hear the tone. Often these spots are not where your favorite chair is located
. In my room the best bass response is located near the back wall!
Most rooms I've known have suffered from variations of this. What most of us hear as "bass" is usually the one (or several) frequencies where the reflections add up to a large standing peak that is much louder (by as much as 20 dB) than any of the rest of the bass. While standing waves and cancellations can be partially smoothed out in a room by effective use of bass traps and other wall treatments that absorb reflections, most people do not go this route. It can be expensive, awkward, and often ugly. There is a page at Audioholics devoted to these problems
http://www.audioholics.com/techtips/roomacoustics/index.php. There was one article I remember called Crawling for Bass, but I don't see it on the list. Maybe someone can point it out.
Another way to improve this problem is with a powered subwoofer and the judicious use of a parametric equalizer. You have to be able to measure the bass response in your room (with the microphone located where you intend to listen), draw a plot of the loudness vs. frequency, and you'll see on that graph where the worst peaks and valleys are. Use the equalizer only to flatten the worst peaks. Leave the valleys alone. Then adjust the volume of the subwoofer so the new bass level is balanced with the rest of the audio spectrum. This should produce bass that is much smoother and more widely localized throughout the room. Many people recommend a Behringer Feedback Destroyer DSP1124P for this. They are widely available and should cost about $100. If you look at the Parts Express web page, under part #248-656, you can download the user's manual and learn more about this digital parametric equalizer.
